block deck surface question
Well I got some of my parts back from my local machine shop. The block was shot peened and the deck seems like it would be too rough to seal properly for a higher boost application. I also have little bits of rust in the cylinders. I'm not real happy with their quality of work. He tried to give me my crank back with 3 chips in the journals that were not there before,but that is another story...
Yikes! The deck should be perfectly smooth...any pics?
Ruh-Roh!
I'll post some in a bit. I think I might just take it to another machine shop.
1 Attachment(s)
1 Attachment(s)
Well I went to another machine shop, and they said I could sand it with wet/dry sand paper on a flat steel block. I used 320 and used WD40 for the wet lubricant to keep the paper clean. It might not look it,but it feels much smoother than before.
Attachment 129701 |
Sorry to hear you were disappointed after all you went through.
Regardless of how Block comes back, I generally take some wet dry paper and WD 40 to the block any way. |
| All times are GMT -5. The time now is 07:10 AM. |
