-   INTERNAL ENGINE MODIFICATIONS (https://www.performancetrucks.net/forums/internal-engine-modifications-158/)
-   -   Biggest LSx cams on the planet? (https://www.performancetrucks.net/forums/internal-engine-modifications-158/biggest-lsx-cams-planet-473942/)
swift700 Dec 16, 2010 01:31 AM
Guys, what's the biggest, most ridiculous cam you've seen for these engines? Who's running a massive cam and how does it work for you? I know some of the Camaro and Vette guys have some big, big lift and duration (along with manual trans or crazy stall converters), but what about us truck guys? Maybe discuss your engine size and supporting mods, too.
THE-HOE Dec 16, 2010 07:03 AM
Does anyone have an MS4 in their truck? I know its not the biggest but they sound freaking nasty.
00Silv4.8 Dec 16, 2010 08:14 AM
There was a dude selling a truck awhile back that had an MS3 and some milled 243s in a 5.3 IIRC.
zero2sixT Dec 16, 2010 08:52 AM
Are you talking roller or solid lifter cams? Biggest roller cam I've heard of was in the 240s
banker099 Dec 16, 2010 09:04 AM
jon (DBRODS) always has a big cam in his engines
00ChevyScott Dec 16, 2010 09:05 AM
Assuming we're talking production cams here (no custom grinds), probably either the
Thunder Racing
"sTRoker" - 248/254 - .615/.623 - 110 lsa
TSP Texas Giant Camshaft
248/254, .615"/.622"
Also, there are other cams with more lift, but these seem to be the largest durations.
TX Tahoe Z71 Dec 16, 2010 09:18 AM
I know it's a custom grind solid roller, but Judson at School of Automotive Machinists makes over 1000hp N/A with this monster cam in his 433 (specs from samracing.com):
Comp Cams 60mm Solid Roller, 278/302@.050 - .985/.920 - 115lsa
03sierraslt Dec 16, 2010 09:18 AM
Krambo is running a pretty damn big cam in his 408
00ChevyScott Dec 16, 2010 09:22 AM
That's a decent size cam, but it's hard to compare solid roller cam specs to hydraulic roller specs
TX Tahoe Z71 Dec 16, 2010 09:31 AM
The OP just said crazy cams for these engines and it's an LSX block, but very true, comparing apples to oranges. To me though, that's a big cam.
