bearings...
Old Nov 21, 2012 | 09:41 AM
Joe4.8silvy's Avatar
Default bearings...
So long story short im getting metal in my oil and im gonna pull the pan and check the rod bearings and i rather have the stuff when i pull it then have to pull it apart again later, so i was looking and the bearings were said undersided and im not sure which i need any help will be greatly appreciated thanks
Old Nov 23, 2012 | 07:57 PM
sand man's Avatar
dont buy anything untill you open and check everything , I learnd the hard way
you might need .010 under or 0.020 under , you might even need a new crankshaft
and you most change cam bearings if they are slightly damaged , the cam and the cam will damage the new bearings unless pulished
agine dont nuy anything untill you pop that motor.
it might be a good time to upgrade to a 6.0
Old Nov 27, 2012 | 10:54 AM
Sales3@Texas-Speed's Avatar
Truck Sponsor
This is true, you will want to check clearances before installing anything. Not checking, and just throwing another set in there could possible result and worse damage.
cdub81
Nov 26, 2012 11:23 PM
JackJare9455
Sep 8, 2012 03:48 PM
silveradokidd_4518
Jan 8, 2011 04:25 PM
silveradokidd_4518
Dec 17, 2010 03:38 PM
LesPaul
Nov 5, 2006 04:53 PM
