Anyone seen a cam bearing like this?
I really have no idea why it happened. I figured something would look like it got hot, but I don't see anything. I ordered new bearings and will install that bearing. The rest look fine. A machine shop installed that bearing, and maybe it was in crooked. When I install that bearing I do it from the back of an engine so I know it's straight. I know I checked the cam by spinning it, and it moved freely or I would have stopped and pulled it back out.
What is your valve spring pressure closed vs. open? Where did the valve break? I've seen quite a few cam, cam bearing, valve and valve guide failures due to improper (too much) pressure with valve springs that are too aggressive. Not saying that is your problem just my experience with these LS motors.
