? About how to tell if '05 6.0 has good rods
I' looking at buying a higher milege HD just for the parts because let' face it, 6.0 and 4l80e are getting up there in price. Found a few in the $2000/2500 range. One has the newer HD hood which is a huge bonus considering I have a 03 (ex cab 5.3). Wondering how to tell if it has the better rods because mid year '05 they came with them from my understanding. Also, is the 14 bolt really worth the headache?
Open up the engine it kind of the only way.
The build date on the truck is kinda up in the air here. It could be a 2004 engine in a early 2005 truck type of thing. The switch over is around the 2004.5ish mark.
14 bolt is worth it if you are going crazy maybe but the 10 bolt is very strong with the right rear locker installed.
My 04 was a factory strong rod motor. The following isn’t proven that I can find, but if it has 13mm head valley cover bolts it has gen4 rods. 10mm head bolts are gen 3. Again this is speculation, but it has held true in every case I have seen. Removing the oil pan is the only sure fire way.
Yeah, I figured that since it has the different hood that it was maybe a updated version. Makes since to use leftovers in the newer years. I just thought it was cut and dry like a hard date. Thanks
I have heard what you said about the bolts before tho.
I bought 2 04 6L that had the 13mm valley bolts and both had the good rods. Then we bought what was supposed to be an 04 5.3 and turned out to be a 4.8, it also had the 13mm bolts BUT had the skinny rods. Maybe just a 4.8 thing but the crossover year 13mm bolt thing isn't always 100%.
rods
rods
