6.0 LQ9 In A Rock Crawler
Old Jun 10, 2010 | 06:08 PM
ss454327's Avatar
Originally Posted by wagnon89
Also I need to get a throttle body for it. Found one I can pick up at the junkyard...or is there one that would give me better performance that would be a direct bolt on with stock intake?
I'm almost 100% the 4.8, 5.3 and 6.0 have the same throttle body.
Old Jun 10, 2010 | 07:37 PM
03sierraslt's Avatar
Stock throttlebody will be fine, for what you want to do that is all that is needed. To the other person, yes a 4.8, 5.3 and 6.0 have the same TB.
Old Jun 12, 2010 | 09:05 AM
wagnon89's Avatar
K. Got the throttle body. Just wondering if having the heads milled would be worth the trouble and to what specs...
Old Jun 12, 2010 | 11:49 AM
53bowtie's Avatar
Honestly no more than a buggy weighs I would just throw the 6.0 in there with headers and good tune and call it good. No sense in going through the motor if you dont have to. Also, check out pirate4x4 for more info, there are tons of guys over there that have done exactly what you are doing. Good luck.
Old Jun 12, 2010 | 07:32 PM
2manycars's Avatar
The easiest way to bump compression in your situation would be to mill the heads. You would really want to with an aftermarket cam of any kind. With a stock cam not as important.
Old Jun 12, 2010 | 09:46 PM
MPFD's Avatar
11 Second Truck Club
OH GOD YES!!! Here is an FTI cam in a 5.3 powered jeep...
http://www.youtube.com/watch?v=OBWEY...e=channel_page
Old Jun 12, 2010 | 10:16 PM
wagnon89's Avatar
Awesome.....
Old Jun 13, 2010 | 02:37 PM
02SilveradoLT's Avatar
lame...
Old Jun 13, 2010 | 05:36 PM
Spoolin's Avatar
GFYS and STFU
Someone already said it but keep the LSA low. The bigger LSA the more geared towards top-end the cam is, the lower it is the better geared for low-end power. Valve list isn't as big a concern, kinda curious why it was brought up actually.
Old Jun 13, 2010 | 09:34 PM
budhayes3's Avatar
PT's Slowest Truck
That Jeep sounds awesome, got cam specs?
