5.3 Won't turn when main caps are torqued
Old Mar 28, 2013 | 05:43 PM
gmcyukon's Avatar
Old Mar 28, 2013 | 06:02 PM
james8997's Avatar
You swapped main caps? Big no no! Main caps are aligned honed to the block. Even swapping two will cause issues
Old Mar 28, 2013 | 06:04 PM
gmcyukon's Avatar
Old Mar 28, 2013 | 06:06 PM
gmcyukon's Avatar
I'll put the other back in and I think I got the wrong bearing too
Old Mar 28, 2013 | 06:14 PM
dirt track racer 81's Avatar
Your middle 3 main caps are back wards, flip them around. You also cannot change main caps.
Old Mar 28, 2013 | 06:57 PM
gmcyukon's Avatar
Ok Thanks guys I will put the 2000 main caps back in and Make sure they're facing the correct way
Old Mar 28, 2013 | 10:50 PM
Well???
Old Mar 29, 2013 | 11:17 AM
Gadgetized's Avatar
^^^this. The stamped number 1-4 will be on one rail, and the 5 will be on the other.
Old Apr 3, 2013 | 03:59 PM
gmcyukon's Avatar
Well???
It worked thanks guys
Old Apr 10, 2013 | 02:25 PM
TexasGMC08's Avatar
Originally Posted by gmcyukon
CAPS 2,3,4 are wrong!!!
