323 to 383 question
I have 8000 hard miles on my 383 stroker now and it's running strong! Never had any trouble with the engine. I've towed 7500+lbs of trailer for 8 hours in the summer heat and it kept perfectly cool. I've made hundreds of full pedal launches and 1/4 mile runs. This is one tough engine.
I'd get the parts, then bring it to your machine shop. Let them know that they will have to bore 1/8 of an inch out of the cylinders and see what they say. My guy bitched that it kept his boring machine busy all day. I'd also recommend ARP studs to go with, the Cometic headgaskets and installing the rear crank seal in backwards if you are boosting. It all worked for me. I torqued the heads 5 lbs tighter than stock specs as well.
Here is the build:
https://www.performancetrucks.net/fo...tblock-478266/
Here is the build:
Here is the build:
Here is the build:
do i need ARP main studs or will my combo be just fine without them?
Also, with the Manley 4" crank and Eagle H-beam rods, my block needed NO clearancing. There was plenty of room.
It's on the shelves right now. Very good 8 page read actually, covering tuning with 93, meth, race fuel, stock 5.3 w/76mm, BW 72mm turbo, compressor map reading, all kinds of good stuff. Clearly in the direction of FI however, not N/A power.
http://i152.photobucket.com/albums/s...1/IMG_1798.jpg
i looked at the local grocery store for that magazine and they didn't have it. i'm going out tonight to "shop" with my wife and ill look for it so i have something entertaining to do while i'm out. thanks for all the info guys. when i pull the engine tomorrow i will take pictures of what exactly it is that broke and add it to my wall of shame in my garage. I called Texas Speed today and should have my rotating assembly by the 1st of march and i have found a machine shop to do the boring and cleaning for 500 bones.
I wonder if thats included with a subscribtion or if its one of those special issues.
I'll be checking my mailbox for the next few days, hah.
I need to figure out what I'll be doing with mine, this will be very helpful. Its good to see more 5.3 builds to.
swift,
great build, just went through your thread. That thing is a beast. The color is pretty cool to.
swift,
