243 heads on my 5.3 07
Hey guys so I'm having alot of doubts....I bought some ls6/799 heads off a 5.3 08 silverado I wanna know Is the HP gain good? Also how bad is the gas mileage drop? And last question is there a difference in sound as far as being louder?...help is very much appreciated
The heads will need to be shaved .030 in order to keep your current compression ratio. You'll more than likely see a little bit more fuel mileage. You cam will really enjoy the extra airflow.
Won't be a bad idea to think about a retune as well. |
no difference in sound... as said above, youll need to mill them to keep your currnet compression ratio the same
The guy I got em from did a good job with milling them and clean em up real good and definetly doing a retune what do yal think as far as HP gain?....I might go from 3.23 gears to 3.73 as well just dont no yet
maybe 20-30 hp gain
Thats what I'm betting on....I got a friend installing em for about 200 so will see soon lop thanks for the help guys....any word on if its a good idea to switch gear ratio to 3.73
3.73 will wake it up bro, or step up one and do a 3.90. . those heads will help that cam breath some more!
Originally Posted by chevy_silverado07
(Post 4897983)
the thing stopping me from switching to 3.73 is I've heard that switching gears makes the truck shake at 100+ so I've heard??
Only if the gears are not installed right (backlash)
