2010 Silverado 5.3 build HELP
Hello i have a 2010 silverado 1500 4x4 with a 5.3 now the truck is sitting on 33s and its rather slow i am also starting to get lifter tip here the qustion i am wanting to do an afm delete so any suggestion on a cam i was thinking ls7 lifters and what are some supporting mods to bring up the power thanks
Jacob_pringnitz (07-29-2018)
i dont really have a budget just wanting as much power as i can get while still keeping it reliable maybe 400ish i was wondering about the gearing how would i re set the speedo thanks
and the afm is messing up the lifter will get stuck in 4 cy mod
Doing the whole AFM/DoD swap is not exactly cheap and picking the camshaft is something that is important here as well.
The basic's are new camshaft, new lifter, lifter trays, new valley plate, new front cover because 2010 also has VVT (that is if you remove VVT and run a non VVT camshaft which is easier in my opinion), new push rods, new head gaskets, head bolts, intake gaskets to be safe as well. I'm sure other little odds and ends too.
Places like texas speed sell kits with the parts you need for the swap, look into that. If you plan to stay with stock torque converter the cam will need to be smaller. Something in the 212/218 range is good for a daily driver while given a decent power bump.
If you want headers at the same time you can, or just stick with stock manifolds which is fine depending on goals and budget. 400hp at the crank can be had easier than 400 wheel horsepower which will need something like forced induction on a 5.3 through an auto with big heavy tires. So low to mid 300's can be done.
Anything you do will require a custom tune from someone or a shop, there is no way around this. They can correct the gear ratio/speedo and transmission shifting for the gear change at that time as well.
This What i had in mind
-Head Gaskets GM PART# 12498544
-Head bolts GM PART# 17800568
-Valley Cover Plate - GM Part# 12598832
-Lifters - GM Part# 12499225
-Timing Cover Gasket Set - Fel Pro Part# TCS45993
-Lifter Guides - GM Part # 12595365
-Cam Thrust Plate - GM PART# 12589016
-Custom dyno tune for XP racing
Heres what i dont know
-Cam what are some specs and what supporting mods
- can i use stock lift springs ?
- stock push rods ?
- new injectors ?
- torque converter
and does anyone have recomdaction on rear end brands or kit
- stock push rods ?
- new injectors ?
- torque converter
Re-read my post.
Already said you need new push rods, aftermarket upgraded valve springs will be wanted and the size cam I suggest would work great or you can go slightly smaller. I also talked about the torque converter briefly, saying if you choose something along the lines of what I said, it's not required.
NNBS trucks have decent sized injectors, if the truck is factory flex fuel they are even larger yet. You will never need new ones with just a cam swap.
Brian Tooley Racing or Texas Speed would sell you a good camshaft. Measuring push rod length or calling and talking with one of them to get an opinion on what you need isn't a bad idea.
Power gains is a toss up. It depending on where you live, what camshaft you pick, what other mods you do at the same time, how good the tuner is. A good random guess is 40-60hp at the tire, a decent pick up in power for sure.
