Ring gap?
Ring gap?
So I’m getting ready to assemble my first LS, I was checking ring gap in the new rings and they’re all at least .024” on the top ring. All the specs I’m seeing say that an N/A engine should run a .016 - .018 gap on the top ring. Am I right in thinking that this is too much gap?
Are you going to boost the hell out of it? If so do a search here as that's in the ballpark if I remember. More gap is preferred. If no boost then maybe too much. Just look around here and you'll find an answer for sure. Sorry I'm not more help.
I squared the ring about an inch down into the bore. The bore is 3.998 on my caliper.
1redta (11-11-2019)
same result. I’ll email the place I got them from, if that doesn’t help I guess I’ll spend some more money.
