Whipple 2.9 on a 6.2, what else?
Bought a Whipple 2.9 for my 17' Sierra w a 6.2. Most of you guys seem to have the Whipples on the 5.3s. What else should I be looking at getting before I put this huffer on?
And what do you guys think of the driveshaft on these newer trucks? Is it gonna hold up and stay under the bed this time? Some things Ive thought about adding were, NW 102 TB Flex fuel sensor setup for E85 Cam setup from LJMS LT4 high pressure pump Some smaller pulleys for more boost 1 7/8" Headers w cats Has Corsa catback already Let me know what you guys think and if Im missing anything? |
Get a driveshaft. LOL.
Put some good lifters in it. Get the piece of shit stock ones out, ive been hearing a lot of horror stories from my dealer friends.
LT4 injectors, Low pressure auxiliary pump. WeaponX motorsports seems to have some nice stuff.
(Post 5463429)
Originally Posted by ZO6Ted
(Post 5463435)
I dont think you will be able to run an LT4 pump with the lower manifold on the whipple, unless they have made a recent change to the make room for it, hopefully they have.
Originally Posted by banker099
(Post 5463502)
Has anyone used the NW 102 on these DI engines and is it plug and play still to factory harness?
I talked to Whipple 6 mo ago and they said no modifications have been made to change anything on the lower. However it seems to be that sometimes the LT4 pump fits without issue and other times some grinding is required. I saw one case where they ground through to the air passageway and had to weld it up. So it is possible to have an issue...or not. But it is totally doable either way. Just be prepared in case.
