Weld S77's
Weld S77's
Is anyone running them on their 14+ truck? I am with McGaughy's knuckles and the wheels hit where the tie rod ends mount and the stud on the lower ball joint. I knew I would need to trim the ball joint. This sucks. $3200 for wheels and tires that don't fit. 17/7 front rears fit fine 17/10..
Thanks for any help.
Thanks man. Cant get picks to load for some reason. So the cure is back to stock spindle and JDM upper and lower control arms. McGaughy's was like whatever your problem. No mention of it on the kit or the web site.
I'd love to see it as well, sucks they don't clear, would a thin spacer get you there? I hate to recommend spacers but a if a thin one works should do just fine. Or thin spacer and some trimming of the spindle?
McGaughy's has no reason to know or care though, they made those to clear OEM wheels. It's always on you to check fitment when going with aftermarket wheels, they can't guess what every single person is going to try to stick on the truck and make a one size fits all.
Brother that sucks, wonder if they'll fit on a 2011 truck with mcgaughs spindles been wanting a set, I ran race stars on a 2011 ext cab and the fit fine, must be different offset, hm!
I had the same problem with my Racestars and McGaughys spindles. I had to put the thin spacer they sell at most auto stores to make it all clear. I think it was like 1/4". I also cut off the extra part of the tie rod end bolt that hangs down, the part thats not threaded.
