Stabilatrack/traction control fuse?
Is there a trac control/stabilatrack dedicated fuse for these trucks? Of course I checked the fuse boxes, but did not see one. The electronic susp control fuse is not for the trac control/stab. Thanks.
You could just push and hold the button to turn it off.
push to turn off T/C push and hold for 3 sec to tun off T/C and Stabilitrac |
Originally Posted by Jordan927
(Post 5269933)
I did not know that.
Originally Posted by SILVER SLED
(Post 5269942)
This is true. However, stabilitrak turns itself back on after 35 mph, or at least once the rear tires are spinning 35 mph.
Yeah I didn't know it turned its self back on...I have been full on sideways in my truck before...and have had it spin right around under power.
There didn't seem to be any intervention at that time... Stabilitrac is part of your ABS...so you could pull that fuse I guess. I don't know what the techII can do with it... TC can be disabled with a tune as its done with spark and fuel. |
The traction control button works just fine, others just pull abs fuse and does everything.
So is this an indicated 35mph? If I'm doing a burn out it turns itself back on during the burnout?
Originally Posted by bigsapper
(Post 5269998)
its real easy pop the fuse box open and look for fuse 25 it will be over number 30 its a small white fuse, it will disable any electronic traction system and the steering will be a bit heavier. have fun and drive safe
