Removing resonator to help with drone
I was going to remove the stock resonator. Then decided against it and left the stock resonator and added one of the hemholtz chambers. So the exhaust is as follows:
Longtube headers, magnaflow high flow cat, borla xr1, hemholtz resonator, stock resonator.
nice. My 3.5” Borla XR1 came in. 40086 part number. Wednesday i’m going to remove the muffler and the resonator and install the xr1 and see how it sounds. going to go with an angled turn down where it isn’t completly turned toward the ground. If it has some drone I want to do the “j pipe” design like you did. AFM will be deleted also once I get a tune so I won’t have to worry about the weird v4 flutter. I think the stock muffler is causing the weird tin-can, pingy noise in my exhaust at this point.
i wouldn’t say quite the same, but same concept. have you read the thread on here about it? lots of the guys ran a straight tube off the exhaust before the muffler and some made a small bend like a J. but i read not to have too sharp of a turn or too many or it’ll defeat the job of the tube.
