Newest times with video of 5.3 ProCharger
Went to Milan Dragway today. It was warm 80 with a DA of 1994-1999 but I ended up running well. Got 3 passes in and all three it hooked fully stalled up.
First pass was 13.31 @ 102.52(1/4), 8.48 @ 80.66(1/8) with a 1.86 60ft. That was left in 4wd for the whole pass. 80 degrees with a DA of 1999.
Second pass was 13.22 @ 102.76(1/4), 8.41 @ 80.99(1/8) with a 1.83 60ft. That was with a 4wd launch and switching to 2wd after the launch. 80 degrees with a DA of 1994.
Final pass was 13.15 @ 103.68(1/4), 8.40 @ 81.87(1/8) with a 1.87 60ft. 4wd launch then switched to 2wd after the launch. 77 degrees with a DA of 1818.
After today I really think with some good air I can see 12's for sure. Video is of my second pass versus a GMC Typhoon that ran 13.30 @ 101. Not sure when my next trip will be to the track but I am very happy with how the truck is running.
Truck moves out for sure! Would surprise a lot of cars from a dig...why are you switching out of 4HI? Your trap speed seems pretty consistent either way so I’m not sure what you’re gaining...I don’t think the transfer case will shift out of 4HI @ WOT, most likely it’s switching to 2WD when you let off...or maybe the newer trucks are different
I had an 06 with auto trac and turbo. It was faster for sure when I switched it to 2wd. On the street if I switched out of 4wd it would immediately blow the tires off at 40-50. That was my experience with a built 4l60e and a stall a little looser than yours. I understand its not the best practice for longevity at least on high hp rides. Im not worried because its not often at all and I'm not putting out much yet. I just dd it 99% of the time.
