Nav tv gm-650
Nav tv gm-650
I purchased the nav gm 650 in order to keep my bose and everything in order so nothing would happen to my truck for a system setup. after a week the sub just cut out so i made sure i had only one ohm on my ground with i did i ran a negative and power wire direct to battery and only had .2 ohms once i called nav tv to inform them this information, all they say is they recommend power the nav box the same way to battery to go in there and find wires im frustrated with them and there service. a bit over priced for a box to be 550$ and not work like they say "plug and play" even doing there exact instructions. So i can do now is recommend a different company for you guys im gonna try someone else now that when i call there lines are either no longer in service i even sent two emails and recieved nothing after two weeks and now its past return "period" of 30 days.
Man that sucks. I've been seeing some issues with PAC stuff too, either from just stopping working or acting up and shutting down the can line communications.
Look into audiocontrol products. From what I understand they are excellent. I'm about to put a audiocontrol lc2i in the wifes car and it's likely what I will run if I do a system in my truck. That or something like the DQ-61
thebadbat
01-06-2003 10:38 AM
