L86 capabilities
Old 03-19-2019, 06:17 AM
l86Denali's Avatar
Default L86 capabilities
Hello all, I have a 2015 Sierra Denali with the 6.2L I would like to supercharge it with supporting mods. I was just wondering what are the weak points I need to address first, I have read somewhere that the ring lands are weak is this true and to what point. any help is appreciated.
Old 03-19-2019, 11:15 AM
ZO6Ted's Avatar
The fuel system is the weak link on these trucks. You will need LT4 injectors if you are going over mid 500's and may need to upgrade the low pressure system as well. An LT4 hpfp is recommended but not absolutely necessary. May as well do it though. The long block is fine.
Old 03-19-2019, 03:12 PM
Jonblarc7's Avatar
I'm pretty sure Fasterproms did around 640 rwhp on his wifes Escalade with a LT4 supercharger. I think the only mods besides the supercharger are cam, ported heads, E85 and LT4 hpfp to this point. I would have to watch some older videos to make sure.
But
That said after this video he did twist the drive shaft in half launch it at the drag strip. But it did pull the front tires once before it broke LOL
Then later he cracked a piston because the brick under the supercharger was leaking water into the pistons and he didn't know.
Old 03-19-2019, 04:09 PM
l86Denali's Avatar
Thank you for your inputs, now I need to get the trans figured out it bangs on downshifts.
Old 03-19-2019, 07:24 PM
00pooterSS's Avatar
The ringlands on these motors are the same as all others, they break when the rings butt together. That's why people open up ring gaps when pushing real high power on stock short blocks. But under 800 or so you should be fine.
The trans should get better once you get it tuned. Try that before rebuilding or replacing it. If a tune doesn't help then it may be a trans issue. Trans tunes on these trucks are a huge deal. As in they all need it cause they all shift like *** when stock. If you have a few miles on it service the trans too.
Is it a 6 speed or 8?
Old 03-20-2019, 06:32 AM
l86Denali's Avatar
Who’s a good trans tuner? I have new era performance in my backyard I know he’s a beast with the engine.
l86Denali's Avatar
I have the 8l90
Old 03-20-2019, 02:04 PM
00pooterSS's Avatar
A really good tuner will know what to do with the trans tune.
I threw out that you should be okay up to 800, that's kind of a perfect world thing. But with a real good tune you should be able to put out a lot and be okay, with a bad tune the ring lands can butt under much lower numbers so a lot of it is in the tune and engine temps etc.
The 8 speed has a new fluid that helps it out read through this
Originally Posted by 00pooterSS
Some good info in here. Apparently there's a new fluid out that GM is going to on the 8 speeds and several guys are saying they are happy with the results.
https://www.gm-trucks.com/forums/top...-issue/?page=5
blue99fbody
02-02-2009 02:30 PM
Turbo 6.0
05-27-2008 11:34 PM
Deckhand
17
06-16-2005 08:29 PM
GONEB4U
02-16-2005 09:19 PM
gilkmanva
12-15-2004 01:39 AM
Quick Reply: L86 capabilities
