Fuel mileage and 6.2 fun.
#21
I can tell you the fuel mileage is what it is on a 6.2. I have every thing done with my truck but gears and boost.
I hooked up HP tuner and only removed the AFM in the tune and touched nothing else. My fuel milage didn't drop one bit.
Then I tuned it with nothing else. Just changing the PE and not locking the converter in gears 1-4 is worth it's price. The Delays in PE are crazy and make your truck feel so lazy.
But after the tune I might have picked up 1 to 2 mpg. I could get 20 pmg with bigger tires.
Then I added E85 sensor, I lost 3-4 mpg depending on my foot. BUT the power it picked up was clearly there and worth it.
Then I hurt a lifter so I did a 218/226 cam and had a local machine shop port the heads. I lost solid 2 mpg.
Next came headers and a wideband. No change in mpg.
Lastly Airad Jr intake and modifidy the stock air box to open it up. I got more air into the engine but gas milage didn't change.
Do all the mods because it will make your truck run better but your not going pick up a ton of mpg. Lower it and put lighter tires and wheels if you want mpg.
I have a ZR1 95mm throttle body and LT2 intake to put on the engine after I get it back from the machine shop from a bad rod bearing. But I don't think I'll pick up and mpg's from that.
#22
I noticed considerable gains opening up the catback, whether it be through swapping the stock muffler for a free flowing muffler and cutting out the flapper valve (got 2 mpg when I did this) or changing to an aftermarket cat back. Either way adds considerable mileage on these trucks.
#24
Who you gonna trust? The guy with no profile pic or the guy with booby pic?
Has anyone tried to see how much increase in MPG they would get with a drop? I would assume that the smaller/lighter tires and the less underneath resistance you have may net you a mile or two?
#26
#27
I've got a 2013. I get 10-12 around town and 15 on the interstate with 93 in Florida. That 8 speed and direct injection sound like they're helping quite a bit.
Is the exhaust different though? I can't imagine that 3.5" factory cat back is that restrictive.... Mine is loud, almost too loud for my taste and that's with the resonator.
#29
I got a 1-1.5 mpg bump changing the stock 6.2 muffler (with no flapper) to a magnaflow verified by my mileage per tank going up around 30 miles per tank
When I had the stock 5.3 exhaust and flapper still in and went to a magnaflow and no flapper I saw closer to 2 mpg.
However, my neighbor didn't see any gain he said, be he also only drives about 5 miles on most trips and his other trips he said he drives foot to the floor for a couple of hours trying to do 100 mph the whole way if possible... so.. he isn't going to see the change. So I dunno man. Could be other factors in why you didn't see a gain. Not sure. You also had some tuning struggles that may have been part of it all.
I didn't notice anything with my drop. I thought the same thing but I don't notice anything there.
Que?
When I had the flapper, I locked it full open and noticed no difference. But when I had the stock muffler cut out and the flapper and a magnaflow put in, I noticed a big difference, and that's comparing to a locked open flapper.
As for fuel mileage. The engine design, the higher compression ratio, the DI, the aero of the truck body and a few other factors really help these newer trucks. Mine is a 2014 with a 6 speed. It gets about 6 more mpg than my 2004 5.3. The 8 speed may help a touch over the 6 speed.
What's most impressive to me is the 6.2, it gets even better MPG than the 5.3 it seems
I got it. I love posting this video lol
#30
Wait,....wtf is this voodoo. I've never seen or heard of this....ever. It just rained so not going there now, but Imma look under the truck and see what I got. That seems so got dang extra on GM's part...wtf.
