Front drive shaft off the transfer case spins
Should the front drive shaft spin while in park with the engine off? Mine spins freely with out moving the rear driveshaft.
I’m getting a grinding sound that seems to be speed based on speed or atleast slower than the engine.
Thanks
Cranked it again a little later and could definitely tell the grinding is in the motor
I put a mechanical stethoscope to it you could hear the clicking/grinding in the motor. The trans,transfercase and diff sound good. Going to hook the scanner to it tomorrow and see if I have a miss somewhere. The light is turn off for my cam. Praying it broke a valve spring again and the dual springs did there job.
lxcoupe
Mar 7, 2016 01:03 AM
