"chevy shake" fix
#31
10 Second Truck Club
Yeah I have videos on YouTube of how extremely out of round the axles flanges are. One of these free days I'm going to pull them and have my machine shop turn them for me.
#33
I didn't have any vibrations when the truck was new but after 60 mine are bad. It's because I lowered it and now the driveshaft is to tight and the pinion angle is off. I'm doing all that next weekend. Hopefully it's fixed
#34
SCSB should have a steel DS on the truck which those are fine don't cause any issues. So it most likely the banacling the the tires alignment of could cause a shack to. Good way to tell if it's the drive line or the tires drive pasted the point of the shacking through the truck in neutral if the truck still shakes it's the tires. If it doesn't it's the drive line.
The NNBS CC and EC have a alnuminum drive shaft that was to long for the truck so after 95mph it was out of balance. I broke one in half at the track at the 1/8 mile with the truck doing 105 a few years back since then I got a custom two piece DS. The NNBS single cabs had a steel driveshaft and didn't have that problem. I don't know which one the 2017 has but either way it should be ok.
#36
I'd like to add a little update.... tire balance and weight is a definite factor. My tires are most likely out of balance at the moment, but I swapped to coilovers and increased the dampening very close to the time I shortened the driveshaft, and found that the vibration is gone. Out of boredom, I reinstalled my McGaughy's struts, and the shake is back, and it's bad as it ever was. having the driveshaft not smashing into the trans is nice, but there is a bigger improvement with higher dampening on the front shocks. my wheel and tire combo weigh 76.5 lbs, which I'm sure is higher than the factory setup, so it feels like the stock stuff is overwhelmed..... I'd like to know if the Silverados that have 22" factory wheels use the same strut as the others. We definitely have the exact same spring as the V6 models, which is a bit weird, but anyway.
#37
#38
I installed Rancho 9000s just to help with the bounce since the stock shocks were marginal when unloaded. It vibrated unloaded or loaded before and still does so no answers here. I have a daily weight of 5900-6000lbs loaded and with the weight it is level front to rear. Thinking Ill do axle mods and driveshaft balance at some point.
#39
Not to get too far off topic ,but what coilover setup are you running Ryan Mills? Viking , qa1? Shaking out of the equation how much better is the ride with them?
#40
I'm using a different bracket setup but I ordered Viking 205 coilovers since I'm lower. And I'll be using an 800lb 9" spring
