2016 Sierra 2500HD 6.0 gasser supercharger question
Old 10-26-2018, 05:07 AM
chacho44's Avatar
Default 2016 Sierra 2500HD 6.0 gasser supercharger question
I just picked up a 2016 Sierra Denali 2500HD 6.0 gasser. My question is if anyone knows if procharger, whipple, maggie, TVS supercharger setups from previous model trucks with LS based motors would work on my 2016 6.0LS based truck? Of course the body is different from older models but seems like there is the same amount of space under the hood, I'm sure intercooler location would need some modifications to work with my year but that seems simple. My main concern is for instance can I run a setup like mentioned above let's say from a 99+truck on mine. Thanks PT
Old 10-26-2018, 08:34 AM
62nalide's Avatar
My buddy puts LSA blower on those
Old 10-26-2018, 01:13 PM
ALL ULL C's Avatar
I wouldn't see why there will be any issues other than if you have a driver side mounted Procharger that you may need to change the power steering reservoir out with a smaller neck. That is really the only physical difference I can see looking at a quick glance. The manifold mounted SC's should not be an issue other than you need a square port kit instead of cathedral.
Old 10-26-2018, 02:34 PM
chacho44's Avatar
Yea it seems like the ps would only be the issue, but not really. LSA swap is on my mind as well so I'd need the adapters. I only have 19k on it, so I have plenty of time to decide. But I might just piece together an LSA setup till the warranty is up lol.
Old 10-26-2018, 06:41 PM
01FormulaTA's Avatar
you won't need any adapters for an LSA blower, the L96 has square port heads just like the LSA 6.2s....and yes any centrifugal blower with the correct truck brackets or any PD blower designed to work with square port heads could be made to work
Old 10-26-2018, 09:46 PM
1994Vmax's Avatar
I would like to see one tuned with the owner actually happy. That E78 ecm is a real beauty... tons of support ( like none) from HP or EFIlive. I haven't yet found someone even successfully activate E fans on them..... sad thing about that is the fleet 2500 and 3500 Suburbans run e fans oem lol.
My truck has ghost knock off the bottom and nothing fixes it.... it's like the ECM doesn't even recognize the changes made to half the tables... probably doesn't.
Old 10-27-2018, 12:45 AM
chacho44's Avatar
well damn I never paid attention to what heads are on my truck
Old 10-27-2018, 12:52 AM
chacho44's Avatar
I was goin to get it tuned in the meantime but haven't gotten around to it. Hoping for the a decent change on it after its done.
Old 10-27-2018, 09:15 AM
1994Vmax's Avatar
My 2017 has been tuned since I bought it new and it pulls quite a bit harder than stock.. although only wants premium at this point which I don't really care. 4.56 gears however really helped in that pulling power department though too.
Old 10-27-2018, 04:44 PM
chacho44's Avatar
I been doin E85 when its available, if not its premium. I have not really looked into the gearing but the Jew swap yours out or did the truck come with 456 gears
Quick Reply: 2016 Sierra 2500HD 6.0 gasser supercharger question
