2015 2500hd no power
Bought a 2015 2500hd 6.0 4x4 WT brand new back in 2015. Fast forward to now. It has 128,000 miles on it and it seems when it gets up to operating temp there is no power like torque management is kicked in or timing is pulled but makes a ton of noise like it is going somewhere but doesn't have any *****. Cold start it runs just like it did from day one super reliable power when you need it. What could it be? It is the WT trim package so I believe it doesn't have afm or dod. All maintenance has been done before it was needed, no check engine light is on.
I was also gonna say sounds like cats.
Feel the exhaust coming out of the pipe at idle and also have someone rev it hard and feel the exhaust coming out. Then go over to one of your other trucks and try the same thing, see if this truck feels like it's outputting a lot less air from the tail pipe.
The only other ways to test it is remove the front 02 sensors and try it, or lower the exhaust pipes from the manifolds and try it. Usually when I see clogged cats you won't even be able to rev it without it choking so driving usually isn't necessary to see if there's a difference after trying one of the above. Or obviously you could replace them and try it but if you guess wrong you're out the money.
thunder550
01-13-2014 09:05 PM
