what motors will swap in the new trucks?
i have a 6.0L built from my old truck, never used it... i assume it wont work on my new truck. question is what motors will swap into the new '08 trucks?
Originally Posted by Noah Burns
(Post 4064563)
thats different, not sure that i would keep that anyways if i swapped motors... i think the reluctor wheel is different also... the cam position sensor might be in a different position too
(Post 4064566)
I don't think the OS is the same in the tune. Maybe with a custom OS with EFILive it could work, but I'm no expert. |
The relucter wheel is the across the board difference.
Then you have DOD and VVT. If you have a 4.8 like I do a new relucter is all you need. |
Find a to get a LS7 in there. Nuff said!:D
Isn't the DOD and everything just in the tune. If you just use the longblock and keep all your current electronics and everything wouldn't it be the same?
You'll need a 58x reluctor wheel. Gen IV cam and front cover with 4x cam sensor. And everything else is will bolt on. Tune to remove the AFM if you have it. You'll also have to make provisions to extend the Knock sensors wires from the side to under the intake.
newer LS2, L76, LY6 or L92 are the easiest swaps.
guess a 6.2L is going to have to be my option...
