welding the open diff carrier in a BW4485 AWD T-case??
I have a 241, with a console, with the oem shift handle and bezel. Honestly making it fit was (in my opinion) far easier than pulling apart a t case and welding a diff that may or may not even have spiders to weld up.
Where there's a will, there's a way. Your will and way is not what I would suggest, my will and way wasn't what you wanted to hear.
Carry on soldier, best of luck to you.
If i end up wanting to make a serious trail rig out of this one, it would involve a dodge front D60, an 11.5" 14-bolt, stretched wheelbase instead of cutting sheet metal, and bumpers. But I'd rather just start with one of my square bodies if i going to build something that hardcore.
it locks the other side up no matter the speed or whether it's under power or coasting. I have tried it all in the snow and the stabilitrack doesn't lock both rears up surprisingly nor does it freak out either.
My stabilitrac has been disabled since I did a rear axle swap (14 bolt into nnbs 07 silverado)
“service stabilitrac” blinks in the information box, goes away after two clicks
traction control and abs light remain on 100% of the time
it bothers everyone everyone who rides in the truck but me, cause I’d rather see yellow lights than be stranded by a 10 bolt
basically, figure out your priorities
rumblebox
Have you tried backing up a slippery surface on a slight cant. Last year with my 08 Denali sierra I almost got stuck trying to back up a snowy driveway. It was just barely up hill but on a slight angle. As soon as the truck would start to slide to the left in reverse, it would kick out of AWD and only use the rear tires to pull. RWD in 8" of snow trying to go backwards up a hill was useless. If I wouldn't of been able to go forward I would have bee screwed. I had to drive all the way down a long steep driveway turn around and park forward. I found out later that if you pull the ABS fuse it will eliminate this problem.
It's Solvable
Mconcha, you should be able to get those features back but not sure which axle and year you used.
To the OP, why not replace your transfer case with a MP3023 and a 4WD front differential and the relevant programming? You're basically turning your Denali into a 2009 Tahoe with the 6.2, a unicorn of which about 600 were built.
You can then run around in 2WD and engage the front diff when needed and even pick up a 4LO capability. Save for labor and programming, the hard parts will probably be a wash when buying the new stuff and selling your old.
It’s a 2007 nnbs vmax semi float 14 bolt with drum brakes. If you find one that’s 09+ it will have disks. I wanted to keep my drums (which is what the 07 came with) so it was a direct swap. I can get my functions back but it honestly never bothered me.
Not a priority then, still isn’t now.
UPDATE: I tore down the transfer case to replace the bearings, seals, and chain only to find teeth missing from the output sun gear and one of the planetary gears. So this went from being just a simple "what if" idea to being an actual project. Stand by for a build thread.
