-   GMT 900 Trucks General Discussion (https://www.performancetrucks.net/forums/gmt-900-trucks-general-discussion-188/)
-   -   Truck pulsing after spark plug and wires changed (https://www.performancetrucks.net/forums/gmt-900-trucks-general-discussion-188/truck-pulsing-after-spark-plug-wires-changed-512828/)
Z71crawford Jan 11, 2013 03:58 PM
Like the title say after i changed the spark plug and wires in my 08 i drove it and at idle if it sits long enough it will start pulsing every few seconds. The truck shakes a little and the RPMs drop a bit then go back to normal. I used Ac delco iridium spark plugs, with MSD 8.5mm wires for a 99-07 truck. Could the wires be the problem although i wouldn't think it would be? I know all spark plugs were locked down just right. What do yall think could be up? Is the computer learning the new thicker wires? Idk but in advance thanks!
nonnieselman Jan 11, 2013 04:34 PM
i had a bunch of problems with MSD wires.. i got the cheapest ones the parts house had and no more problems..
i even got MSD to replace 4 of them and still no worky..
put your stock ones back on and see what happens.
shorty's garage Jan 11, 2013 04:40 PM
I think anything from msd is junk. I make my own wires.
AUTOT3K Jan 11, 2013 05:26 PM
Did you use diaelectric grease?
That's an insulator not a good conductor
Z71crawford Jan 11, 2013 06:57 PM
Yeah I think I may send these back! No I didn't use the grease. Probay go back to go old ac Delco
Chevy_King1500 Jan 11, 2013 07:23 PM
8.5mm msd wire worked great on my truck. you need to make sure they are 100% on the plug end.. they can be a little tricky
i would put the stock ones back on. if the problem still persist you may have cracked a plug..
Atomic Jan 11, 2013 07:23 PM
Crack the porclein on a plug?
iamkeniff Jan 11, 2013 07:54 PM
Shi i run TR-55 (5.3) an TR-6 (6.2) bosch wires. Cheap plug and wire change with no issues :)
Z71crawford Jan 12, 2013 08:47 AM
Trucks getting the 4.56s installed right is so ill do investagation when it get back.
LS1FREEK Jan 12, 2013 09:30 AM
Ive had 3 sets of MSDs and never had a problem. If I had to guess, you may have cracked a plug.
