Thoughts on slotted drilled rotors
If you decide to upgrade the flexible section of brake lines, be extra sure the lines are approved for road use. Does Canada have something like the US D.O.T.? I've run Goodridge stainless braided lines with a thick clear nylon sleeve on a couple cars as they were the only DOT approved stainless brake line. Crimped ends were correct orientation and perfect fit on every install, after some 80k miles on the first install they still looked new.
I bought Powerslot drilled and slotted rotors and Hawk pads. There was a significate difference in braking capability on my truck, no increase in noise and I am not noticing an increase in brake dust. I would purchase them all over again.
So, it takes a little time to do it, but if you want to change your brake fluid the "easy" way, I just use a turkey baster and suck out as much as I can and replace it. Then rinse and repeat every evening or drive there after for a bit. But good pads do make a huge difference!
You need to look into a Motive Products power bleeder! I replace the fluid in the master, then use the tank dry to just put pressure on the reservoir, bleed the calipers, remove the tank and top the reservoir as needed. It's a true one person operation and less mess and time than putting the fluid in the tank.
Wholesale Direct
51
02-09-2005 06:15 PM
Wholesale Direct
08-10-2004 11:38 AM
Wholesale Direct
06-24-2004 04:26 PM
Wholesale Direct
44
05-13-2004 01:37 AM
