Snow Performance Methanol Injection Installation
17 Attachment(s)
I just finished the installation of a Methanol Injection kit by Snow Performance on my truck. It is a 2007 Silverado NBS, 5.3 N/A, cammed, full bolts ons, custom cylinder heads. The kit I chose is part number 20012. The control unit uses the MAF sensor signal to activate the methanol pump. There are 2 adjustments on the controller to set when the pump will come on and at what rate. I have been experimenting with different on times under different driving conditions to see how it feels. I am very happy with the performance so far. Later next week I am going back to see Justin and we will put it on the dyno for another tune. Overall it is a very simple installation. Here are some pictures of the install.
Here is the motor after the cam installation. Attachment 142833 Components included in kit. Attachment 142834 I upgraded to the large reservoir. It fits perfect on the battery tray in the left front. Attachment 142835 Under the battery tray is a bracket, this was the perfect place to mount the pump. It is hidden and looks clean. Attachment 142836 Attachment 142837 Attachment 142838 I installed the injector very close to the throttle plate. I tapped the Volant intake and threaded in the injector. The injector flows 375 ml/min. Attachment 142839 Attachment 142840 The control unit is a simple 4 wire hook up. Power, ground, power to pump and MAF signal. I mounted it to the left front fender. Attachment 142841 Attachment 142842 I tapped into the MAF signal wire at the PCM. Attachment 142843 Attachment 142844 Next I tapped into switched ignition power for the controller. I went from the bottom of the fuse box so all the wires are hidden. Attachment 142845 Attachment 142846 I covered the red tubing and ran it up with the engine harness. Attachment 142847 Attachment 142848 Attachment 142849 The last addition I did was a green led mounted on the instrument cluster bezel. It comes on when the pump is activated. I want to thank Matt and Ray at Snow Performance for their help and support on this project. |
dude what is the water cross over set up? thats so cool looking! anyways, thats a cool looking motor. wheres the truck pics? ;)
Motor looks real good. Curious to see gains being na. Are they the kurt urban crossover pieces?
1 Attachment(s)
Originally Posted by iamkeniff
(Post 4599412)
Attachment 142850 |
sob you added more pics after i posted :drool:
Very clean install! Interested in NA gains as well!
Originally Posted by Rhino79
(Post 4599582)
Hmmm Meth on N/A eh? Interesting Im subscribing for results. Please show with meth and without for us popcorn munchers
Ever any results using meth on a N/A engine besides 10%-15% power increase and cooler temps..... Looking at the Snow Performance Stage 3 MPG-MAX Kit.
Thought about this install more than once. Get us some results. What kinda price did it run ya?
| All times are GMT -5. The time now is 01:32 AM. |
