silverado 6.2L numbers
#21
Ok thanks! Are you running a ati damper 8 rib? I was running around 9.5psi on the 2.8" blower pulley but when I did the cam it dropped to 8psi. Where did you get the 2.7"? 2.8" was the smallest I found but that's a 6 rib never looked into 8 rib yet. Thanks
#24
Just wanted to give an update. I got the innovators west 8 rib set up with a 2.7" blower pulley and a 10% overdrive crank pulley, made an intake tube to run a cold air and added meth. I now need a fuel pump and bigger injectors they are maxed out and dropping fuel preassure pretty bad at wot. She put down 598/592 much better! Tuner said I'll be well over 600 when I get a fuel pump and injectors!
#25
I bought a TVS1900 for my 12 6.2l. It came with pink 42lb @58psi injectors. WAY to SMALL. My stock 52lb injectors were at 99%idc. I was at 8psi. You should be using meth at 8psi. I had same setup as you but stock cam on 285/50/20. 436hp 435tq
#26
Mine came with black injectors. I didn't have them bench tested but the tuner said they were bigger than stock from the data logs and thinks they are 65lbers but I have no clue. I guess the drivetrain on these trucks eat up a lot of power or the tvs1900 is just too small and inefficient for the 6.2. It made ok numbers but was expecting more
#27
#28
No I didn't. It's safe where it's at. The trans in #1 on the list. It's still a stock 6l80e with a stall converter. It's doing better than the shop that I got it tuned at thought. They said it'll need a trans before winter but it's still kickin haha
