Rough country lowering kit?
Old Jun 6, 2013 | 08:10 PM
Fiveminutes's Avatar
well it should be 2 up front
i decided to ditch the rough country bracket and just set the strut at 2" drop
the rear is supposed to be at 5"
not sure why its at 6"
Old Jun 6, 2013 | 10:26 PM
hawaiianstyle's Avatar
Raja that!! I guess I'm going to go your route, bell tech struts and rough country kit. Did you have a big problem with your pinion angle???
Old Jun 6, 2013 | 11:01 PM
atxlt's Avatar
So you now just have the strut mounted at the bottom without the bracket for a 2" drop? Do you have and pictures of that?
Old Jun 6, 2013 | 11:15 PM
RS/SS 4.8's Avatar
10 Second Truck Club
How much u want for that drop bracket for the strut. PM me
Old Jun 8, 2013 | 08:57 AM
yup, flip kit with lift shackle and shocks for 200 is still a good deal.
im getting slight vibration at around 70+mph, not sure why...i heard its just like the mcgaughys kit with set pinion angle and center pin hole on the saddle. not sure if that extra inch made a difference.
no, the strut is mounted on top like normal, i just have belltech adjustable struts set at 2" drop
Old May 15, 2014 | 12:48 AM
20002wdchevy's Avatar
14 Second Truck Club
Just finished he rough country kit on my truck but with the spindles instead. Plan on ordering shims for the pinion. Mines pointed at the moon! They didn't design any angle into the flip kit which is crazy and they don't include any or even sell any on their site. I'm trying 4 degree shims first (should be about perfect). I get vibes on takeoff 30mph. 50mph 70mph etc. Overall the kit was a breeze to install though and I would recommend it for someone on a budget. Just get pinion shims!
Old May 15, 2014 | 02:00 AM
lowoh8's Avatar
not a bad price.
Old May 15, 2014 | 03:24 PM
TheSuspensionSource's Avatar
FormerVendor
Let me know if I can help you. We have a few different options depending on what you want to achieve.
Old May 15, 2014 | 03:25 PM
FormerVendor
If you have a CC/EXT then you may need the transmission spacer by Belltech
Old Oct 23, 2014 | 03:25 PM
LowMarcus's Avatar
Registered User
Smile 2014 Silverado Rough Country 2/4 Lowering kit
I hope this helps someone and saves a little time...I just finished lowering
my 2014 2wd Silverado Crew cab....the kit worked great, flipping the drivers
side spring was a little nerve racking, mainly cause i was so scared to screw something up. However here is the problem I ran into, when you reverse the
bolt that squeezes leaf springs together, the new axle cup or craddle if you will,
the hole provided in it will not go over the pin head of said bolt. So we opened
the hole just enough. worked great. after completion on test drive had vibration between 20-30 mph. called Rough Country, they said no problem we'll send you a set of 6degree shims. they came with bolts and nuts and no instructions. the bolt replaces the previous mentioned bolt but the pin head on it is smaller, which would have fit perfectly in the craddles provided....all is good now no vibration after shims installed. point of this story is go ahead and order the 6 degree shims up front and you'll have the right bolt.....you'll probably need the shims anyway. wish they came with kit and were mentioned in their instructions..The Front process was very easy to do.
