Pulling motor and converter install - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 06-10-2017, 09:08 PM   #1
Default Pulling motor and converter install
Kind of two questions here but If i pull the motor, would I be able to just pull the old converter and install the new one? I thought I read somewhere that the trans had to be pulled and put on its tail shaft to add fluid to the new converter but I had never done any converter installs before and wasn't sure if this was necessary or not. Secondly, whats the easiest way to pull the motor on the nnbs trucks? I know the intake needs to come off(mine already is) but will the accessories, crank pulley, and water pump clear the fan shroud or will the all need to be removed?
TAPyvehc93 is offline   Reply With Quote
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
