Poly trans mount
Has any one found or used a poly trans mount?
Using Energy Suspension's online catalog sucks. I will use AFP poly engine mounts eventually, but would like a matching trans mount. It's in a '08 CCSB 6L80E AWD setup. |
I used the standard chevy poly trans mount I think it was summit branded and I had to grind a little bit to open up the mounting holes that bolt to the trans because they're offset a bit. Easy to do. Used a dremel after measuring. On my 09 rcsb rwd.
