Please Help!!!P 2135 code for Throttle Pedal Position Sensor
Old Jan 21, 2014 | 08:43 PM
Default Please Help!!!P 2135 code for Throttle Pedal Position Sensor
I have had this come up (and go away) when driving recently and my power is cut dramatically (50 mph max) and get messages about servicing traction control and stabilitrac. If any of you have ran into this...what needed to be fixed??? The DBW gas pedal, throttle position sensor, or other???.
Thanks for your help!
Old Jan 21, 2014 | 08:46 PM
AUTOT3K's Avatar
whats the rough mileage?
factory TB?
Old Jan 22, 2014 | 06:53 AM
11Denali's Avatar
Pretty sure this was a re-call... maybe check with the dealer first though
Old Jan 22, 2014 | 11:03 AM
My truck has about 85k and is running the factory throttle body.
I did some more research and it sounded like it was the TPS in the throttle body assembly or a loose connection to one of the throttle body wires.
The good news for me is that I have a spare throttle body that is ported which includes a TPS.
I will likely swap tonight and see if my problem ever comes back.
Old Jan 22, 2014 | 12:17 PM
03sierraslt's Avatar
Two guys I work with had the same issue. It was the TPS in the TB.
Old Jan 22, 2014 | 09:43 PM
AUTOT3K's Avatar
that's what I was getting at, cause a long while back I had received a letter from GM Canada saying if I had those issues to bring it in
tweeder
Sep 18, 2015 11:02 PM
smokeshow
Aug 23, 2015 08:23 PM
Denali08
Aug 9, 2015 04:34 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
GreyChevy
Jul 7, 2015 08:57 PM
