Oil Analysis After Mods
1 Attachment(s)
hey guys
so after I did all my mods (listed in sig) I did the old school cam break in period where you run it for 20 minutes at various rpms then change the oil and filter. this oil sample is AFTER that break in oil change and driven for close to 5,000KM (3,000mi) I had no real reason for doing it other then I wanted too, and I was curious how everything looked. I attached the sheet for you guys to see |
Cool....how much was that to have done?
Originally Posted by Atomic
(Post 5128800)
I paid an extra $10 for that bottom section testing, which also tells me how much further to go...I wont do that test next time, just the normal test. AND even though they said go longer...I'll still do it old school at 5,000KM haha:jest: |
Blackstone is a great resource. They can tell you exactly whats going on inside your engine.
Blackstone is who I use as well. Like said above, great resource to give you an idea of what's going internally. I tried some various oils during testing as well and tat's what led me to use Rotella t6, I used to be a mobil 1 fan...
How much do you pay for RP? Why not run amsoil for that money?
Edit: what filter did you use with it? Thanks for sharing it! |
Originally Posted by cjlee13
(Post 5128960)
Originally Posted by Kemble
(Post 5128973)
Changing it at 3K miles he could run plain old conventional with the same results.
(Post 5128979)
Require dexos. That is atleast syn blend. :(
(Post 5128985)
Gm never intended for there to be anything other than a stock camshaft in the engine as well.
