NNBS Escalade gauge conversion
#21
Tin Foil Hat Wearin' Fool
Mine is a SLT little mod I did was put a 140 MPH police face on my OE cluster. I like it way better than the stock and you get the little tick marks between speeds so you actually know if you are say 72 or 73.
Based off of the wiring diagrams for it all you need to do is swap the cluster and replace the plug. Programming could be kinda finicky to get it nailed down so you do not have odd ball warnings for this and that. But I haven't ever got to actually pull one of these clusters and compare them side by side.
Electrically the truck talks to the escalade cluster the same way it does the standard clusters but the esky uses a different plug.
#23
Where did you find that 140 speedo face, and how much was it (if you don't mind)? Sounds cool.
#28
I reflashed it for the tahoe. But then I flashed it to my stock calibrations and it was dead nuts on both ways using my tech 2 to to verify everything was correct and by the garmin on the windshield. I dunno go figure sometimes gm changes stuff for a reason othertimes they change **** just to make you think it's different but it's the same I think this was one of those cases. I had a rough day I just got in def get pics up tomorrow for yall.
Yeah the truck is too new to bastardize it too far by playing with replacing clusters to much PITA.
