Need help with passenger side window 07 Yukon
One night i took my friend girl ito to eat and when we got inside of the truck she was trying to let the window down but i had the window lock on. I told her hold on let me unlock it but she was still pressing it as i was unlocking it and both of us were trying to let the same window down at the same time. Now it doesn't do anything. The window was stuck down. I had to pull the pdm fuse and put it back in to let it up but it only lets up in increments. Like it's skipping. So i tried a new window regulator and motor and same thing. I tested the ddm and it was good. Pdm had a dtc on tech 2
Window Motor Fast Over Current Fault
Possible Causes:
B3205 0BThe DDS or PDS has detected excessive current flow on their respective window motor control circuit.
My question is that I've read there are fuses on the back of the interior fuse panel and also under the dash. Are there any circuit breakers for the pdm on those or window motor for passenger side?
Trouble Code: B3205 0B
Possible Causes:
I get alldata which is VERY expensive through my library for free on a reference computer. Usually the larger branch libraries have it and you will need a library card. The second suggestion, since you did not include a picture of your friend girl, find a replacement for her at the library too! LOL
MarineBlue03GMC
08-05-2006 08:57 PM
Frito Bandito
04-28-2006 10:14 PM
