Is this a necessary sensor?
Yes you would want to keep that. These trucks vary the battery voltage literally all the time, it's never just charging at exactly 14 volts so it needs to know the current the charging system is at 100% of the time.
The sensor itself is called a battery current sensor.
Thanks. I figured it had something to do with voltage regulation but had no idea what.
Do you know if there is any reason why you can or cannot run small gauge wires next to large gauge wires?I know there can be interference with speaker wires being next to larger wires but can I run the sensor wires next to the 4 Gage alternator wire?
Same reason you shouldn't run speaker wire with the 4 gauge amp power cable.
One doesn't have to keep that, unplugging it lets the alternator run at full capacity all the time. Some folks like that, it's also a cure for flickering lights. Nice to have though and seems to help battery life. To each his own.
Unplugging the GBCM causes the truck to charge to 13.8v which is lower than if it was hooked up and working.
You also have to make sure every ground cable from the battery negative post goes through that sensor. If not, your truck will charge very high like 15v+
You sure about that?
For what it's worth my harness is dead stock with that sucker in place, and I did just replace my negative cable with a GM piece routed back through the way the original was. Old cable had some corrosion wicking down it which I think may have been screwing with the charge rate..
Richard
