Tubbing NNBS Tahoe
Jegs, summit, Chris Alston, there's several places to get wheel tubs. Look up Sloshtubz and see if Mike has anything that is appealing to you. If you're looking for square ones, gm replacement wheel tubs might better fit what you're after. I didn't have to widen the square ones in my '85 C10 because they're pretty wide already. They're definitely square!
Tig (06-09-2017)
I'll be doing some searching this weekend.
How much room do you need? Stock wheel wells moved up and inward toward each other, then painted, always look the cleanest IMO.
Then again not many people are going to see it. They'll most likely be hiding behind the rear seat depending on the size anywhoo..
