My 2007 VortecMax 4L70E to 6L80E swap and how to.
#21
So I cant use the 2011 ecm at all or does the tuner just have to start from scratch on the 2011. The reason im trying to use the 2011 ecm is because the tcm is a 2011 and its easier to change the ecm than the tcm. Maybe ill just habe to bite the bullet and change the tcm.
#23
TCM connectors
Are the TCM connectors the same for 2010/2012 to the 2008 style if they need to be changed? I'm looking onto this swap also and found a 2010 trans for a good price.
#25
2007 Silverado 4l60e to 6L80E
I am in the middle of this swap and have hit a snag. I have a 2007 Silverado Regular Cab Short Bed That originally came 4.8/4l60. I already had my 6.2 in it and now I’m swapping the 6l80 in. The hard parts are no problem at all I own a Performance & Fabrication Shop and we do a good bit of L’s swap work. My problem is the harness. I have a brand new harness from GM part number 20822436 and the large oval connector under the fuse box is larger than mine. Everything else is the same, changed fuel pump connector from 10pin to 8pin. I’m stumped. I don’t mind ordering another harness but wanna make sure it’s right. Hers is a picture of said connector on new harness. Mine is smaller than this one and there is 15 wires in mine vs 32 in the new harness.
05GMC4.8
08-07-2015 09:55 PM
04BlackGmc
07-16-2015 04:10 PM
