Anyone run this btr stg ii boost cam 32631134
ANYONE RUN THIS CAM WITH A PD BLOWER, WHAT IS YOUR VAC AND TIMING AT IDLE?
BTR STG II BOOST CAM 32631134
CURRENTLY MY SETUP
2011 SILVERADO CC/SB 4WD
FACTORY 6L80E TRANS
9.5" DETROIT TRUTRAC
3.73 GEARS
LYSHOLM 2300AX W/ 3.25" PULLEY
LS9 HEAD GASKETS
ARP MAIN/HEAD STUDS
WISECO FORGED PISTONS W/PIN
UPGRADES-FACTORY BORE
W/ K1 RODS - GM CRANK
BTR STAGE 2 TURBO CAM
COMP PN#32631134
COMP ADJUSTABLE TIMING SET
COMP MATCHED DUAL SPRINGS
COMP HARDENED PUSHRODS
COMP SHORT TRAVEL LIFTERS
COMP TRUNION ROCKER UPGRADE
VVT & DOD DELETE
CAMARO THROTTLE BODY
RAND MCNALLY DUAL VALVE PCV
SNOW DUAL METH NOZZLES (2x #5'S)
---CURRENTLY ON@3PSI - FULL@6PSI
KOOKS 1 7/8 LONG TUBES
W/3.5" CATLESS MBRP EXHAUST
CURRENTLY MY SETUP
FACTORY 6L80E TRANS
3.73 GEARS
LS9 HEAD GASKETS
ARP MAIN/HEAD STUDS
COMP PN#32631134
VVT & DOD DELETE
Sub, I've been thinking about this cam as well as the vvt stage 2.
