Mcagughys spindle question on a 2011 GMC - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 05-09-2017, 09:31 PM   #1
Default Mcagughys spindle question on a 2011 GMC
Guy's I done one of theses on a 13 couple of years ago but I guess you flip the bearing around on the spindle and bolt it in from the outside ?, also is the bearing a pain to get out the old spindle, the ones I've changed came right out usually, not these, THANKS!
fillpot is offline   Reply With Quote
Old 05-09-2017, 09:34 PM   #2
psycho1's Avatar
If it's the hub bearing assembly you will need a hammer to knock it off. If it's the same spindle I did you have to put a stud and not on the top and the rest should be the stock bolts.
psycho1 is offline   Reply With Quote
Old 05-09-2017, 09:55 PM   #3
That's it, but it comes in from the front and not the back with the new spindle ?
Old 05-09-2017, 10:15 PM   #4
I'm thinking that the stud goes on the front side of the spindle and the two factory bolts go back threw the rear of spindle like stock if this makes sense.
Old 05-09-2017, 11:58 PM   #5
psycho1's Avatar
Quote:
Yes the stud from the front and the other 2 bolts from the back. So before you put the hub back on put the stud in first on the top from the front then put hub on. Then tighten the 2 bolts in the back and then put the nut on the stud and tighten.
Old 05-10-2017, 10:17 PM   #6
Good deal, I'm on the right track, now if I can just get time to finish it lol. THANKS!
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
