Mcagughys spindle question on a 2011 GMC
Guy's I done one of theses on a 13 couple of years ago but I guess you flip the bearing around on the spindle and bolt it in from the outside ?, also is the bearing a pain to get out the old spindle, the ones I've changed came right out usually, not these, THANKS!
If it's the hub bearing assembly you will need a hammer to knock it off. If it's the same spindle I did you have to put a stud and not on the top and the rest should be the stock bolts.
That's it, but it comes in from the front and not the back with the new spindle ?
I'm thinking that the stud goes on the front side of the spindle and the two factory bolts go back threw the rear of spindle like stock if this makes sense.
Originally Posted by fillpot
(Post 5408537)
Good deal, I'm on the right track, now if I can just get time to finish it lol. THANKS!
