LS2 LS7 Throttle Body on a GMT900 5.3
Old Jun 1, 2010 | 06:00 PM
  #31
markislive78's Avatar
13 Second Truck Club
Originally Posted by iamkeniff
just dont want to drive to work on DRs lol
It's legal right?
Old Jun 1, 2010 | 06:23 PM
  #32
iamkeniff's Avatar
yep but i don't want to drive on em to work...
Old Jun 1, 2010 | 06:40 PM
  #33
Mrgoodwrench3's Avatar
Well I picked up a 12570790 today and it is not going to work. If the actuator side of the T/B is to the left it will not clear the alternator. If I rotate it 180 degrees it will open from top to bottom. I will be getting the 12605109 tomorrow.
Old Jun 1, 2010 | 06:43 PM
  #34
iamkeniff's Avatar
mines flipped and it opens top to bottom no problems
Old Jun 1, 2010 | 07:12 PM
  #35
Decided to try anyway. Installed tonight and drove 30 miles home from the shop. It works perfect without a glitch. I can say I do have a smoother more positive acceleration. It should also be noted I am running a Vararam VR2 LS2 T/B spacer. It brings the T/B out about 2 inches from the manifold. My previous T/B was the stock 87mm that was ported. My last Blackbear tune was with the ported T/B and spacer. I think the tune made it easier to adapt to the new 90mm LS7 T/B.
Old Jun 1, 2010 | 10:12 PM
  #36
Preston129's Avatar
Hmm, never thought of it running into clearance issues with the alternator...Markislive78, is yours flipped too or does it clear the alternator?
Old Jun 2, 2010 | 12:10 AM
  #37
iamkeniff's Avatar
mine is flipped
Old Jun 2, 2010 | 09:25 AM
  #38
Preston129's Avatar
Even with the spacer you ran into clearance issues with the alternator? How did you end up mounting it? actuator to the left or right?
Old Jun 2, 2010 | 09:44 AM
  #39
iamkeniff's Avatar
if you're using the car tb you have to mount the actuator on the passenger side anyways bc that's the side where the plug is and you cant put it the other way and make it work bc the harness isnt on that side.
Old Jun 2, 2010 | 10:02 AM
  #40
Preston129's Avatar
Ya I noticed that the harness wasn't very long when I disconnected it yesterday. So when you said you flipped yours, I thought that meant the actuator was on the right.
