Low oil pressure, only slight fluctuation with throttle - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 12-21-2017, 06:02 PM   #1
Default Low oil pressure, only slight fluctuation with throttle
Truck in question is a 2008 originally 5.3. It had some problems so I got a 6.0 l96 from a donor vehicle. The oil pressure was 40 at warm idle wile it was still in the donor, don't know how it reacted with throttle also don't know what weight oil it had. I got it swapped over and filled with castrol 5w30 now it only has ~25# at idle and only goes up to 30 with throttle causing the gauge display to show a oil light and low oil pressure.
It has a lsx 454 cam, new lifters, and new headgaskets. Dod/afm deleted. And new oil sending unit.
I've narrowed it down to one of 3 things.
Oil pump (pressure relief valve)
Or the rubber orings that seal the lifter towers (didn't want to drill for plugs due to obvious reasons and can't afford the fancy pop rivet tool to plug them)
And to me, the less likely, bearings as it had good oil pressure before being pulled with the only variable being oil viscosity.
Any one have any ideas as to what is more probable or other probabilitys?
LOWnEASY is offline   Reply With Quote
Old 12-21-2017, 10:51 PM   #2
I had a similar issue with the 5.3 in my wife's tahoe after I did the dod/afm delete. I bought the ligenfelter dod plug kit and my oil pressure went back to normal. I just used it on my 2007 silverado when I did the dod/afm delete and oil pressure is steady at 40 at idle.
Deezl SS is offline   Reply With Quote
Old 12-22-2017, 10:04 AM   #3
Wana rent the tool out? I can buy the plugs, it's the tool I don't want to pay $75 for and use once or twice over the years.
Old 12-22-2017, 05:55 PM   #4
swathdiver's Avatar
The L96 does not have DOD/AFM. 25lbs at idle seems normal once warm. 25-30 while cruising below 2000 rpms is also normal.
So if you did take out AFM components from that engine, it was not an L96, maybe an L76?
swathdiver is offline   Reply With Quote
Old 12-22-2017, 08:45 PM   #5
Tig
Tig's Avatar
Quote:
Is this the kit you got?
https://www.lingenfelter.com/product...l#.Wj2sq0xFzIU
Tig is offline   Reply With Quote
Old 12-22-2017, 09:45 PM   #6
It may not have dod/afm but it still has the lifter towers with the holes in them.
And 25 lbs is low enuff to make my oil light come on and my display read low oil pressure stop engine, altho I know it's not low enuff to hurt any thing it's just annoying seeing the lights on the dash.
Old 12-22-2017, 09:47 PM   #7
Quote:
Originally Posted by Tig View Post
Should be. That's the only kit I'm aware of. It's like $7X on summit. Pricy for a rivut gun. Wonder if the "rivet" plugs would work in a standard rivit gun?
Old 12-22-2017, 10:43 PM   #8
Tig
Tig's Avatar
Quote:
Originally Posted by LOWnEASY View Post
Should be. That's the only kit I'm aware of. It's like $7X on summit. Pricy for a rivet gun. Wonder if the "rivet" plugs would work in a standard rivet gun?
That's exactly where I was going haha
Though the rivets do look pretty beefy
Old 12-23-2017, 01:12 AM   #9
swathdiver's Avatar
That's correct but you mentioned that the AFM/DOD was deleted.
Hmm... Doesn't sound right, has the computer thrown a code P0521?
Old 12-23-2017, 04:10 PM   #10
My 17 is an L96 and it only makes about 25 psi hot idle... never goes over maybe 55 pounds but once hot its likely below 50. Seems to be normal and on par with most others. As accurate as the factory clusters and sending units are it might be worth checking otherwise.
1994Vmax is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
Oil Cooler installed, slight drop in oil pressure...questions Hemi Killer GM Engine & Exhaust Performance 6 05-09-2010 04:56 PM
Shawty got low low low low low low low low WhySoSerious? SHOW & SHINE DISCUSSION 16 05-16-2008 12:38 AM
RPM fluctuation NightmareTBSS GM Engine & Exhaust Performance 1 06-21-2005 08:06 AM
Voltage fluctuation-alternator going? Procharged LM7 GM Engine & Exhaust Performance 17 11-01-2003 04:24 PM
4.8 5.3 Idle Fluctuation - Hi Pedal Effort 1999 to 2002 LS1csherm GM Engine & Exhaust Performance 9 09-02-2003 12:48 PM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
