jus bought the new escalade dash and interior any advice
oh realy ya i drove through there didnt stop tho i wish i would have known u were there i would have stopped to check out ur truck its so sick! and ya i hopefuly i can get the new interior in soon
i just started going myself ill send u a PM friday if i go again and see if u stop by its way better than the Dallas meets lol
You will also need to get the a/c air box and harness from an ltz slt etc unless yours has electronic dual zone a.c already in order for the a.c to work correctly. If all of the modules are programmed already it should work right off as soon as you get it all in. If you get into it and have trouble let me know I can get it all working for you. You need a/c box and harness and door harness' for an slt or ltz chevy pickup if you didn't get them from the donor. You will need to splice the wiring that runs to the rear of the truck for doors windows speakers domelight etc. You may run into brake light problems with the programming of the stock BCM because the tahoes escalades etc use a serial buss module in the rear of the vehicle for brakelamp control whereas your truck uses a 12v signal out from the bcm directly to the tail lamps. You'll have to get it all installed then sort the bugs out one at a time.
Very badass, LMK if you want any help. I live in North ft worth off 35. I'll be doing the same thing except with a full Denali interior in a reg cab GMT900 Sierra really soon and would like to learn as well. I think you may need a new escalade bcm to make it work. Seems like I read that somewhere that it is a bit defferent and mounts in a diff spot.
Does your truck currently have it? If not you will need to replace the air box with one from a slt or ltz sierra or silverado with dual zone as mentioned in my post up a few from this one.
