Help with cam specs???
Can tell me what the stock cam specs are on a nnbs vortec max 6.0?
Nobody???
191/190 duration at .050 0.457/0.466 lift on a 114 Lobe ...
i dunno them, but why you wanna know the specs are you planning a cam swap?
Originally Posted by RibeiroBJJ
(Post 4528572)
1 Attachment(s)
LQ9 6.0L TECH SPECS:
Part Number: 19156262 Engine type: LS Series V-8 Displacement (cu in): 364 (6.0L) Bore x stroke (mm): 101.6 x 92 Block (P/N 12572808): Cast iron with 6-bolt, cross-bolted main caps Crankshaft (P/N 12569768): Nodular iron Connecting rods (P/N 12567583): Powdered metal steel Pistons (P/N 89017478): Cast aluminum Camshaft type (P/N 12561721): Hydraulic roller Camshaft lift (in): .467 intake / .479 exhaust Camshaft duration (@.050 in): 196'c1 intake / 201'c1 exhaust Cylinder heads (P/N 12562319): Aluminum, symmetrical port Valve size (in): 2.00 intake / 1.55 exhaust Compression ratio: 10:1 Rocker arms (P/N 10214664): Investment cast, roller trunnion Rocker arm ratio: 1.7:1 Recommended fuel: 92 octane Maximum rpm: 5600 Reluctor wheel: 24X -LOL just jokin..both specs I got from a quick google search.. |
If you need a Vortec "miny" 191/190...I have one that I will sell ya! :rotflmao:
Thats lq9 specs... nnbs 6.0s have ly6s in them...
Originally Posted by skipperdaddy
(Post 4528622)
Yeah I don't have the lq9 in my nnbs. Im going to get a bigger cam but not to radical so that gm doesn't notice when I take it in for warranty work. I like the topend, but need more lowend power. And since I am going to tune it, I'll probably get an extrA PCM to swap out with if it need to go to the shop. Does anyone recomend blackbear , wheatly, or Nelson tunes over the other I've always done live tunes but want to try something different on the new truck.
