HELP!!!!!!!!! A/C Belt Replacement - Without Tensioner
Swapping cam, get to the A/C Belt removal before removing crank pulley and I do NOT have a belt tensioner on my A/C belt. I plan to put on a Ud pulley once the cam work is finished so should I just get the belt off any means necessary and then buy an ideler pulley for the A/C belt or what is the trick here?
Help a brother out!
Help a brother out!
I cut mine off
Then going back on I used socket and ratchet to turn crank and a screwdriver to walk the new stretch belt on.
When it comes time to do udp like you ill probly buy the tensioner and bolts like mentioned
Sounds like a plan. From what i see on SLP's website there is only one accesory belt listed, so my truck would need a tensioner regardless to utilize the pulley and have A/C.
lxcoupe
13
11-20-2015 08:43 PM
SlvrSierra4.8
10-01-2015 09:39 PM
Hpinnovate
09-04-2015 02:28 AM
