09-13 8.6" 10 Bolt Diff
Has anyone built theirs? What parts did you use? Was thinking about getting Moser chromoly axels, harden diff cover. Already have factory LSD with 3.55 gears,Calvert Bars, really don't want to spend the money on fully built moser diff. Thanks
How much horsepower and torque are you trying to put through it? This is essentially the same differential in our 1980s Buicks and we put over 500 horses and even more torque through them with no problems.
What gears you running?
This the correct cover http://www.taperformance.com/proddet...prod=TA%5F1807
3.73 Gears. Only things I notice with the Detroit is there's a bit of sway in the rear from it engaging when I'm lightly on and off the throttle and once in awhile it'll make a pretty significant snap sound, usually when I let off the brake after pulling up to a red light. Other than that it's fantastic, no ratcheting around turns and 100% locked when it see's power so you need to be mindful of that on curves on the highway.
That is the cover I ordered.
