GMT900 Hydroboost Conversion How-to
Old 11-15-2013, 12:39 PM
  #21
I hate my cats
Wyttrash96's Avatar
Alright, just got everything swapped in, attempting to bleed the steering, not sure if I'm getting it though. The brake pedal isn't getting any stiffer though. I thought since the brake and steering hydraulics are now tied together that bleeding the steering would bleed the brakes too. Am I wrong? Do I need to bleed the brakes seperately?
Old 11-15-2013, 06:03 PM
  #22
mdwatts11's Avatar
I think so, I am pretty sure the fluid for the master cylinder is different than the hydroboost.
Did you do this on an nnbs? Did you make any progress on the dash light/warning?
Old 11-15-2013, 06:37 PM
  #23
I hate my cats
Wyttrash96's Avatar
Yep, 08 VMax. I haven't bothered with the SERVICE BRAKES SOON message yet though, no. I also have an extra electrical connector that was plugged into the booster, and an unused plug recepticle on the right side of the pump. Anyone know what these are?
Old 12-05-2013, 06:03 AM
  #24
Foxxer's Avatar
Yes sir, nnbs, fluids are different and I couldn't remove the warning too.
Old 12-14-2014, 03:24 PM
  #25
iamkeniff's Avatar
Factory fitting at the Rack. Def a bad GM design for us that want hydroboost
Old 05-21-2015, 11:21 PM
  #26
iamkeniff's Avatar
Any chance anyone found out how to disable the "service brakes soon" yet? Mine still says it, but it doesnt bother me
Snddoc1 (10-13-2023)
Old 10-24-2015, 02:25 PM
  #27
mdwatts11's Avatar
Can anyone confirm if you can reuse the original master cylinder like you could on the nbs trucks? I am thinking you can avoid the extra headache of the different size fittings on the brake lines by just swapping over the master cylinder.
Also, no one has had any luck with the 'service brakes soon' message?
Old 10-24-2015, 03:06 PM
  #28
iamkeniff's Avatar
Idk if you can find a booster that has the same "spread" for the master. I have not had different boosters in hand to compare to my oem master.
I have not figured it out yet, but i do know that no matter how you jump the harness it does not clear the code like the old swap. You do have an ABS plug, that all you have to do is wire together to keep it from throwing the ABS lights.
I am planning to compare ohms on am oem setup asap
Old 10-24-2015, 04:18 PM
  #29
Three6GMC's Avatar
i got mine to work without saying the service brakes soon message. I just capped off the end that went into the brake booster and left the sensor connected to the intake.
Old 10-24-2015, 06:05 PM
  #30
mdwatts11's Avatar
Do you have a part number for the master cylinder you used, and did it require any funky fittings to get your brake lines to work with it?
So, you just capped it with a rubber cap and left it dangling where it was originally by where the booster was?
Did you jump the wires on the abs sensor like iamkeniff said?
Thanks for the help guys. I am trying to figure out all of this crap before I start ordering stuff to do the swap.
Quick Reply: GMT900 Hydroboost Conversion How-to
