GMT 900 illuminated Door Sills OEM Install & Pics
19 Attachment(s)
Guys I found a good price for some OEM illuminated door sills for my Denali and figured I would share some pics and a quick how to, as I couldn't find any good pics.
GM Part # (this could be out of date, so verify before you order) 19171554 "Chevrolet" (white) 19171555 "GMC" (red) 19171556 "Escalade" (white) Escalade 19172905 "Cadillac" [cursive script] (red) 19202873 "Denali" (white) Denali Attachment 110874 Attachment 110875 Attachment 110876 Attachment 110877 Attachment 110878 Attachment 110879 Ok its a very simple and straight forward install: The sills come with instructions including the hole templates Here's my quick how to install version: 1. Remove the door sill/s, A-pillar kick panel/s & fuse panel cover/s, pull carpet back to run the wiring harness. Attachment 110880 2. R&R metal inserts from the sill assy... by folding the tabs back to a straight position and the inserts just fall out. (I don't think a pic is needed) 3. using the temples drill a 1" hole in the forward section of the sill assy... I did this in steps, stepped up to a larger bit each time, as the plastic is soft and can tear ( the hole is to allow the transformer through) Attachment 110881 Attachment 110882 Attachment 110883 4. Remove battery ground, R&R BCM Body Control Module. (located just above the OBD2 port behind the knee guard panel) Attachment 110884 5. RR pink connector or J6 connector from BCM Attachment 110885 Attachment 110886 6. Install the Power/Positive pin into J6 connector "pin 1" Attachment 110887 Attachment 110888 7. Reinstall J6 pink connector & BCM and run the wiring Attachment 110889 8. Install ground wire (ground location is just behind the parking brake pedal, it gets a new nut as pictured on the right, left is old R&R old and replace with new style) Attachment 110890 9. Route the wiring to the illuminated door sill, and run the wire to the passenger front side. (reconnect battery, then check operation of door sills before reinstalling trim panels, note they are very dim in the day as they are white light) Attachment 110891 Attachment 110892 10. Reinstall all panels and sills be careful not to pinch the wiring. Click the image below to watch a short video http://i123.photobucket.com/albums/o...ps78f534b7.jpg |
Nice! How mich did that set you back?
Originally Posted by WICKEDOWESIX
(Post 5141875)
I did this a couple of days ago, very nice mod, IMO.
Already hacking it up
Looks good!
I've got a set of these coming, i'm excited to see them.
So is the gm part number for the kit with replacement sill plates, wiring, led and all?
My truck doesnt have any emblems on the door sills, so would I need new sill plates and all?
It comes as a kit in that part number.
Idk if you would need all new sill plates or not. |
